Falcon I - Can't clean
  • Falcon I - Can't clean
    My Falcon I 64 GB has bad sectors. So I tried using the clean utility from firmware 1916.
    I selected the right model (Samsung K9HCG08U1M-PCB0) but I have this error :
    Error indilinx ssd not found
    Any idea about how I can resolve this ?
    Thanks.
    PS : I did try the other model (Samsung K9HCG08U5M-PCB0), just in case of it could work, but of course it didn't work (I get the error described in the firmware 1916 thread, first picture of step 10).
    hi paindepice,
    did you plugg the jumper or not? if you didn't using the jumper, it will showing the" error indilinx ssd not found"
    . also try with other model as well.
      Yes, I plugged the jumper. I know it was rightly plugged because I could upload the 1916 firmware.
      As said in my original post, I already tried the other model...
        hi,
        there's two different 1916, one is Falcon and other one is Falcon II, please make sure that you are using correct firmware. if still can't using Clean funtion, please conatct rma@gskill.com
        we will replace it for you.
