Gskill when will you be releasing the 4.0 firmware update? Thanks
Firmware 4.0 release date?
Hopefully it will fix the performance degradation from 3.2 vs older firmware.
And please, don't forget to another "IMPORTANT" step in one of your procedure, which is, to know what does it fixes.
Rather than like the 3.2 firmware released, which gskill just tell us to blindly apply it cause you only tell us the current problems that are NOT fixed rather than what are fixed, that is quite embarrassing imo.
