This is my Falcon where i have my windows 7 x64 installed and i just thought to run this bench , i havent ran any for over a year, and this is the result. I ran the bench from the same 7 x64 installed on the Falcon.
1 Should i run it from some other OS on another disk ?
2 Will wiper restore performance?
3 Is that probably because i haven't used the wiper since i installed the OS ?
4 A matter of not enough free space maybe ?
5 Are the latest fw (2030 lets say?) allowing windows 7 to use trim on this SSD? if so are the results good?
6 What is the difference between "garbage collection" and TRIM ?
7 What are my options for using this SSD with XP ? To run Wiper every here and then ? Will it work if the fw is 2030 ?
8 With XP should i keep Intel Storage Manager or install the Rapid Storage Technology drivers?
