Most of you know that the ICH10R supports trim, but some of us like to RAID our platter drives for temp caching and game drives. To make it short I was using this method on the ICH10R chipset with all drives, but when I ran wiper utility it wiped my SSD clean of all data with the Hard drive RAID enabled. Frustrating for some but there is a workaround, since I am using a ASUS PX58D-E Board it has two Southbridge controllers, on Intel and the other Marvel. The fix I used was moving my Raptors to the Marvel 6GB controller and keeping the SSD independent on the ICH10R chipset. Finally success, I can run wiper and takes no hit with the RAID array on the separate controller and its butter smooth. Now far as putting SSD's on the Marvel will be a no go since it can't pass a trim command. I just wanted to share this little experience with the users on the board and hope it may solve some potential problems for some potential RAID users.
Falcon I with Hard-Disk Raid on ICH10R Fix
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
RAM 12Gb Patriot Viper Xtreme Division-2 DDR3 @ 1908Mhz
PSU Corsair AX 850W
SSD: Intel X25M 80Gb
HD 2x WD VelociRaptors 150Gb in Raid-0
Sager NP8662
CPU: Intel Q9100 @ 2.38 GHz
GPU: GTX 260M @ 612Mhz
RAM: G.Skill DDR3 1066Mhz 4Gb
SSD: Intel X25M 120GbTags: None
