So I bought an Asus G73JH-X1 notebook and ordered the 120gb Phoenix Pro SSD to give it the final kick it needed. The problem is that when I install the SSD into the primary slot I am unable to run the restore disks to install the OS. Additionally I tried a Win7 disk and it started the process but then errored out. Now if I put the SSD in as a secondary drive, then I have no problems reading or writing to the SSD at all. Asus thinks its an issue with the SSD, but that makes no sense to me.
Bottom line...is there some trick to putting an SSD in as the primary drive ? This is my first time with an SSD so I am kinda learning as I go, but it seems like the only real difference is the performance, and not so much how you install it.
Thanks in advance!!
SliGuy
Thanks in advance!!
SliGuy
