Phoenix Pro 60GB FW package 2.1 A or B?
  • Phoenix Pro 60GB FW package 2.1 A or B?
    I have a Phoenix Pro 60GB SSD. Do I want to use the "A" package or "B" package to update it?
    Thanks for any info.
    only one of the packages will work
      If the package you choose does not correspond to your SSD, it will not allow you doing the update.
      Then choose the other one.
