I have a Falcon 128gb SSD which has worked flawlessly for me for about 6 months now. I left my computer turned on overnight and this morning it was unresponsive. I turned off my PC and restarted to find that the bios is not recognizing the SSD. I also disconnected the power and reconnected the power cable. After checking the SATA cable connections to the SSD and the motherboard I turned the pc on again and had the same lack of response.
I changed the SATA cable and changed the SATA location on my motherboard from 0 to 1 and the bios still refuses to recognize the SSD is attached. I even changed to another power connector from my Power Supply with no response.
Is this SSD suddenly dead, or is it more likely the cables or motherboard? Any advice is welcome.
