Trident Z RGB software may not be fully uninstalled from time to time, possibly from rebooting before clicking "Finish" or interference from other software, causing software issues in subsequent installations.
This guide is for a deep clean for the Trident Z RGB software (specifically, v1.06.68). Please read each step carefully and follow each step in order. If a folder or file is not found at the specified location, then it's likely to be already removed by the standard uninstall process.
Step 1: Go to "Add/Remove Programs" in Control Panel, and uninstall the G.SKILL Trident Z RGB software. Make sure to complete the uninstall process and click "Finish" to complete the uninstall.
>> REBOOT after the uninstall. <<
Step 2: Open Task Manager, Go to "Services" tab, Find "LightingService", Right click on it and choose "Stop". (If on Windows 7, then go to the "Run..." dialog and type in "services.msc").
Step 3: Delete the following directories:
C:\Program Files\ASUS
C:\Program Files\G.SKILL International Enterprise
C:\Program Files (x86)\ASUS
C:\Program Files (x86)\G.SKILL International Enterprise
C:\Program Files (x86)\LightingService
Step 4: Use a registry cleaner (such as CCleaner) and clean the registry for any missing or residual entries.
>> REBOOT after cleaning the registry. <<
Step 5: Go to C:\ProgramData\Package Cache\ and check the following directories, and you are looking for the file inside the folder.
If you cannot find this directory, please open "File Explorer Options" (or Folder Options), go to the "View" tab, and under "Hidden files and folders", choose "Show hidden files, folders, and drives". You can come back to this option location afterwards to revert the setting.
If the directory does not exist, then no action is required.
If the directory and file exists, right click on the file and choose "Uninstall". If the option to "Uninstall" does not exist, then choose to "Run as Administrator" and choose to uninstall when prompted. If it asks to install, then click "Cancel". After the above steps, you can delete the file if it does not remove itself after the uninstall process.
C:\ProgramData\Package Cache\{0E536061-3B55-4D45-BF58-0BDA261C94B0}v3.02.24
>> "AuraServiceSetup.msi"
C:\ProgramData\Package Cache\{46EEF4E1-2117-4D64-A953-F1DE092495EB}v1.00.10
>> "AacSetup.msi"
C:\ProgramData\Package Cache\{4961d0dd-74e6-4696-abce-8f69a5badc6a}
>> "AacSetup.exe"
C:\ProgramData\Package Cache\{548dd834-70c5-4426-8065-fbeabdd2bb5d}
>> "GlckIODrvSetup.exe"
C:\ProgramData\Package Cache\{5960FD0F-BB3B-49AF-B175-F77DC91E995A}v1.0.10
>> "DrvSetup.msi"
C:\ProgramData\Package Cache\{9a2e950f-6116-4c9f-a3ca-1f907a52747e}
>> "AuraServiceSetup.exe"
C:\ProgramData\Package Cache\{CF8E6E00-9C03-4440-81C0-21FACB921A6B}v3.02.06
>> "SdkSetup.msi"
Step 6: Shut down, turn off the PSU manually to cut power, wait 15-30 for the power to drain, then turn the PSU back on, boot into Windows, and then run the software installer for Trident Z RGB.
The Trident Z RGB modules should light up in default rainbow wave mode during boot. If it does not, then there may be a hardware issue. For hardware issues, please contact techsupport@gskill.com (International), ustech@gskillusa.com (North/South America), or eurotech@gskill.com (Europe) for further support.
>> "AacSetup.msi"
>> "AacSetup.exe"
>> "DrvSetup.msi"
>> "SdkSetup.msi"
