My pc had a BSOD that has to do with memory management. I ran many tests in Memtest86. Here is my most recent one:
Summary
Report Date | 2024-07-08 22:13:27 |
Generated by | MemTest86 V10.7 Free (64-bit) Visit MemTest86.com to Upgrade to Pro |
Result | FAIL |
EFI Specifications | 2.70 |
System | |
Manufacturer | ASUS |
Product Name | System Product Name |
Version | System Version |
Serial Number | System Serial Number |
BIOS | |
Vendor | American Megatrends Inc. |
Version | 3607 |
Release Date | 03/22/2024 |
Baseboard | |
Manufacturer | ASUSTeK COMPUTER INC. |
Product Name | ROG STRIX B550-F GAMING (WI-FI) |
Version | Rev X.0x |
Serial Number | |
CPU Type | AMD Ryzen 7 3700X 8-Core |
CPU Clock | 4050 MHz [Turbo: 4050.6 MHz] |
# Logical Processors | 16 (8 enabled for testing) |
L1 Cache | 16 x 64K (223899 MB/s) |
L2 Cache | 16 x 512K (71101 MB/s) |
L3 Cache | 1 x 32768K (25927 MB/s) |
Memory | 32697M (14700 MB/s) |
RAM Configuration | DDR4 2134MT/s / x2 Channel / 15-15-15-36 / 1.200V |
Number of RAM SPDs detected | 2 |
SPD #0 | 16GB DDR4 XMP 2Rx8 PC4-28800 |
Vendor Part Info | G Skill Intl / F4-3600C16-16GVKC |
JEDEC Profile | 2134MT/s 15-15-15-36 1.2V |
XMP Profile 1 | 3602MT/s 16-19-19-39 1.35V |
SPD #1 | 16GB DDR4 XMP 2Rx8 PC4-28800 |
Number of RAM slots | 4 |
Number of RAM modules | 2 |
DIMM B1 | Empty slot |
DIMM B2 | 16GB DDR4 2Rx8 PC4-17000 |
Vendor Part Info | G Skill Intl / F4-3600C16-16GVKC / 00000000 |
SMBIOS Profile | 2133MT/s 1.2V |
DIMM A1 | Empty slot |
DIMM A2 | 16GB DDR4 2Rx8 PC4-17000 |
Test Start Time | 2024-07-08 17:20:29 |
Elapsed Time | 4:51:16 |
Memory Range Tested | 0x0 - 830000000 (33536MB) |
CPU Selection Mode | Parallel (All CPUs) |
CPU Temperature Min/Max/Ave | 47C/75C/59C |
RAM Temperature Min/Max/Ave | |
TSOD0 | 0C/0C/0C |
TSOD1 | 0C/0C/0C |
# Tests Completed | 48/48 (100%) |
# Tests Passed | 33/48 (68%) |
Lowest Error Address | 0x2155A05A8 (8533MB) |
Highest Error Address | 0x2175A7BC8 (8565MB) |
Bits in Error Mask | 2000000060000000 |
Bits in Error | 3 |
Max Contiguous Errors | 1 |
CPUs that detected memory errors | { 0, 4, 12 } |
. | . | x | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | x | x | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | . | .. |
63 | 0 |
Test | # Tests Passed | Errors |
Test 0 [Address test, walking ones, 1 CPU] | 4/4 (100%) | 0 |
Test 1 [Address test, own address, 1 CPU] | 3/4 (75%) | 1 |
Test 2 [Address test, own address] | 4/4 (100%) | 0 |
Test 3 [Moving inversions, ones & zeroes] | 3/4 (75%) | 2 |
Test 4 [Moving inversions, 8-bit pattern] | 2/4 (50%) | 3 |
Test 5 [Moving inversions, random pattern] | 2/4 (50%) | 2 |
Test 6 [Block move, 64-byte blocks] | 1/4 (25%) | 53 |
Test 7 [Moving inversions, 32-bit pattern] | 2/4 (50%) | 9 |
Test 8 [Random number sequence] | 2/4 (50%) | 2 |
Test 9 [Modulo 20, ones & zeros] | 4/4 (100%) | 0 |
Test 10 [Bit fade test, 2 patterns, 1 CPU] | 4/4 (100%) | 0 |
Test 13 [Hammer test] | 2/4 (50%) | 2 |
Last 10 Errors |
2024-07-08 19:43:16 - [Data Error] Test: 6, CPU: 12, Address: 2175A7A08, Expected: 40000004, Actual: 00000004 |
2024-07-08 19:43:16 - [Data Error] Test: 6, CPU: 12, Address: 2155A7A28, Expected: 40000004, Actual: 00000004 |
2024-07-08 19:32:44 - [Data Error] Test: 4, CPU: 12, Address: 2155A05AC, Expected: 02020202, Actual: 22020202 |
2024-07-08 19:18:50 - [Data Error] Test: 13, CPU: 0, Address: 2155A05AC, Expected: 963A4380, Actual: B63A4380 |
2024-07-08 18:42:49 - [Data Error] Test: 8, CPU: 4, Address: 2155A722C, Expected: AF4DBB58, Actual: EF4DBB58 |
2024-07-08 18:28:10 - [Data Error] Test: 7, CPU: 4, Address: 2155A722C, Expected: BFFFFFFF, Actual: FFFFFFFF |
2024-07-08 18:28:10 - [Data Error] Test: 7, CPU: 4, Address: 2155A05AC, Expected: 00010000, Actual: 20010000 |
2024-07-08 18:28:10 - [Data Error] Test: 7, CPU: 4, Address: 2155A0F94, Expected: FFDFFFFF, Actual: DFDFFFFF |
2024-07-08 18:20:08 - [Data Error] Test: 6, CPU: 4, Address: 2175A7BC8, Expected: 40000200, Actual: 00000200 |
