Basically, I just got a new desktop and for a about a week everything was working fine and was using the ram with XMP enabled no problems But one day the PC took ages to turn on and I started getting crashes during games, the more demanding the game the faster the game or the PC would crash, the PC was turning on normally after that one time but i couldn't play anything without either the game crashing or the PC just shutting down and rebooting and that has been happening ever since that day. After about 10/15 mins it crashes or if the game is not that demanding it can take from 30/60 mins for that to happen
After a lot of troubleshooting I found that if I disabled XMP everything ran fine so the problem was with the XMP
Normally this would be a simple answer, the ram couldn't run at XMP overclock because of compatibility issues with the motherboard but if that was the case why did it work fine for a week straight and stopped working out of nowhere?
I didn't change anything in drivers or bios or even installed anything to justify this change in behavior
I ran windows memory diagnostic and memtest86+ and both sticks came out with no issues so it's weird to think it was faulty RAM but what's weird is it working with XMP on the exact same games for a week straight
Is this really a compatibility issue or should I RMA the sticks to check for problems?
The RAM I am using is Ripjaws V DDR4-4000 CL18-22-22-42 1.40V 32GB (2x16GB) F4-4000C18D-32GVK
The PC specs are:
Mobo: Gigabyte Z790 AORUS ELITE AX DDR4
CPU: Intel Core I7-13700K
GPU: Gigabyte GAMING OC RTX3080 10GB
PSU: Corsair RM1000x 1000W 80+ Gold
Storage: Kingston NV2 1TB
The PC specs are:
