What are my results: seems quite ok(medium), so what to try to make it faster? b-die Samsung Revision B1 8layers
G.SKILL Trident Z Royal DDR4-4000 CL16-16-16-36 1.40V 32GB (2x16GB) F4-4000C16D-32GTRSA
Tried
4000 Mhz - Voltage 1.5V, VCCSA 1.24V VCCCIO 1.2V stable
4100 Mhz - Voltage 1.5V, VCCSA 1.24V VCCCIO 1.2V stable
Got Erorrs 4133 Mhz - Voltage 1.51V, added till VCCSA 1.25V added VCCCIO 1.21V - (couldn't boot at 1.5V)
Seems 2T is only possible, what is better tighten then?
Anybody with similar modules welcome to share.
PS. Work at default 4000MHz without errors in tm5 or Aida64 stress memory test on auto settings at my motherboard Gigabyte Z490 VISION G (rev. 1.0) + Intel i9-10900KF with Voltage 1.5V, VCCSA 1.25V VCCCIO 1.2V
EXTRA Question-
Read many DDR4-FAQs but with BIOS parameters in GYGABYTE Need some help - attach my BIOS memory settings - not sure about what to put:
Memory timing mode - Fixed or Dynamic.
Realtime memory timing?
Memory Boot mode?
Channel-rank interleaving!?
Don't touch FSB 100MHz ->133Mhz?
Tried
EXTRA Question-
Memory Boot mode?
