Hello G.SKILL
After setting up a new system last weekend I had some stability issues with my ASRock B450M PRO4-F and a F4-3200C16S-16GVK RAM module. I bought the 16GB module in a sale thats why I didnt buy 2x8GB.
Now the question that I am asking is less about the stability issues anymore. I had 2 random screen freezes last weekend. But now, 2 days later (the time it takes to register here) the system seems to run smooth. I solved the issue by changing some screen cables it seems.![Smile](https://www.gskill.us/forum/core/images/smilies/smile.png)
Anyways in the process of figuring out what could be the reason for the 2 random freezes I found out that my ASRock B450M PRO4-F and a F4-3200C16S-16GVK RAM module is not really a good combo since considering your compability list this mainboard does not support this kind of ram. (2x8GB would be fine)
Atm the system seems to run smooth. But I still ask myselfe if it would be smarter to return the 1x16GB and buy 2x8GB that are 100% compatible with the mainboard.
Also considering some tests this RAM module seems to run very poorly in this system. How much of a speed boost is dual cannel anyways?
Contacting my reseller would be a bit of a hassle since I cant just send it back like on amazon..And I would also have to pay another 20-30$ or so..
Thank you for the feedback.
Sysinfo:
CPU: AMD 3300x with the stock cooler
RAM: 16 GB F4-3200C16S-16GVK - a single 16GB module not 2x8GB
Mainboard: ASRock B450M PRO4-F with newest BIOS
SSD/HDD: Samsung 970 EVO 500GB (main) and 3 older 1TB Samsung HDDs
GPU: NVIDIA GeForce GTX 1060 6GB
OS: Win10 Pro
Case: An old Antec home server case with a large top fan keeping the temps at about 45°C.
Newest drivers are installed.
Sysinfo:
OS: Win10 Pro
