Can anyone help?
I have an ASUS P9X79 PRO motherboard. When I put in the Gskill ram (4x4GB) my computer BIOS will only see 12GB when I put the memory in the recommended slots. I did update the BIOS to the latest version (1203). After that I reset the BIOS to the default settings.
The RAM I bought is:
F3-12800CL9Q-16GBXL
When I put in all 4 sticks into the recommended slots (A1, B1, C1, D1), I only see 12GB when I should see 16GB. Annoying. I tried just 2 chips in the first 2 slots and I see 8GB. Tried the other 2 chips in the first 2 slots and I see 8GB (so RAM seems to be ok). I did try to put the 4 sticks in the first 4 slots (A1, B1, A2, B2) and it saw all 16GB. Not sure why, and what that will do since it's not the recommended configuration.
I talked to ASUS and they were no help. We tried to change the DRAM timing settings but that did not help. They suggested I buy a different brand a RAM.
Any thoughts on why the board will only see 12 of the 16GB?
thanks,
Peter
Can anyone help?
F3-12800CL9Q-16GBXL
thanks,
Peter
