Recently I bought 2 packages of the RipJaws 8 GB kit, part number F3-10666CL9D-8GBRL. I installed all four sticks (16 GB) in a new system using a Gigabyte GA-Z77-DS3H motherboard and Intel Core i5-3570K CPU, as well as other components that probably aren't relevant here. OS was Windows 7 Ultimate 64-bit.
Right off, things did not work as they should. Whenever the system went into "Sleep" mode, it would not resume properly, or, sometimes, at all. I observed at least two different behaviors:
-System would repeatedly power cycle. Usually on the 3rd try, it would pause for a very long time, then eventually resume, but not always.
-Other times, system would power up, but then hang before reaching the "Resuming Windows..." stage. No display, no error beeps. In this case I had to hard power-off (by holding down the power button for several seconds), then upon turning the system back on, it would go through an ordinary POST sequence, as if I had done a cold boot, and then it would finally resume from sleep.
I have another system with DDR3 RAM and also running Windows 7 64-bit, so I swapped RAM modules around. Eventually I determined that one of the pairs of G.Skill modules was causing the resume-from-sleep problem. It happened in both the above-named system, as well as a much older one using an Asus P5E3 WS Pro motherboard and Intel Core 2 Duo (E8500) CPU.
With known-good RAM, both systems resume from "Sleep" mode almost instantly, particularly the newer one since it uses an SSD.
So I'm fairly certain one of the pairs of G.Skill RAM is faulty, even though Microsoft's memory testing program failed to find a problem.
Did I miss anything?
