register
Think about the closest thing currently available that'll run 2400/CL8/9 is a 2x4GB set, F3-2600C10D-8GTXD, which is 2600/CL10 and will run at 2400/CL9 or a loose 2400/CL8
The set I mentioned is 2600, but since you mentioned 2400, I tried to explain they will run at 2400 with a tighter CL than the stock CL10 it's rated for at 2600
No problem, but if looking for 8GB or more, suggest 2x4GB. Two sticks places less strain on the MC (Memory Controller) than does 4 sticks, and allows room for further expansion
