Command Rate (CR)
  • Command Rate (CR)
    I have a ASUS M4A88T-M with a Phenom II X6 1055T, 2.8GHz OC'd to 3.3. At this time I have one piece of F3-12800CL7D-8GBRH, one of a two stick kit. The RAM shows it is running at CR 1T in CPUz and I can't find the setting for it in my BIOS.
    I do have it at stock settings and timings. I understand 1T can over-stress the CPU MC.
    (I have just the one stick in for testing and I will reinstall the OS and it will be a X64 Win 7, currently X86)
    I'm sorry Dave, I can't do that.
    Some motherboards it is AUTO detect for CR. I think this is one of the motherboards.
    1T is fine, especially one module. If the system needs 2T, it will AUTO change to 2T.
