Looking for upgrade advice for-
ASUS M4A88TD-V EVO/USB3 AM3 motherboard
Not sure if I want to max the board out at 16GB or just get 8GB.
Current RAM I have installed-
G.SKILL ECO Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBECO
Processor is-
AMD Phenom II X2 555 Black Edition Callisto 3.2GHz Socket AM3 80W Dual-Core Desktop Processor - C3 Revision HDZ555WFGMBOX currently unlocked to 3 cores.
After researching Newegg reviews, I have seen claims that these G.Skill RAMs work on this board
2 things
1. Do the kits listed above generally work, or can you recommend additional-
16GB (4x4GB) kit(s)
and
8 GB (2x4GB) kit(s)
2. Now I know that is not recommended, but would it be possible to install this-
Sniper Ram Model #:F3-12800CL9D-8GBSR2 (2x4GB)
alongside my current RAM. If it doesn't work with the stuff I have installed now I could always remove it and sell the old stuff online.
Processor is-
- 16 gig G.SKILL Ripjaws Series 240-Pin DDR3 1333 (PC3 10666)
- 4GBx4- GSKILL F3-12800CL9Q-16GBRL
- two sets of g.skill F3-10666CL9D-8GBRL
2 things
16GB (4x4GB) kit(s)
and
8 GB (2x4GB) kit(s)
