Greetings.
I just put together a new build.
i5-2500k
F3-12800CL9Q-16GBXL
ASRock Z77 Extreme4 (QVL list: http://www.asrock.com/mb/memory.asp?...Z77%20Extreme4 )
Windows 7 64bit
I am experiencing lockups and BSODs when using 2 or more sticks. Lockups occur during BIOS POST and also when within BIOS. When these occur, green artifacts usually appear as well. BSODs occur during windows loading screen and of course within windows as well - if I get lucky enough to get that far.
Windows memory disagnostics produced no errors. But I did experience a glitch where text on screen would only slowly refresh, one vertical line at a time. Whether that was an issue with the ram or windows itself, I do not know.
Using memtest86+ 4.20b (only one I could get to work) revealed thousands of errors initially, but after noticing that memtest showed freqs at 11-11-11-26? I went back into my BIOs and set XMP settings (9-9-9-24 @ 1.50v). I ran memtest again for some 6 hours, producing 0 errors.
From what I can gather, any combination of sticks, on any combination of slots, produces these results. Using only one stick appears to be stable, but perhaps I haven't waited long enough.
As of right now, the odds of...
Locking up during BIOS POST: very high
Locking up inside of BIOS: inevitable
BSOD followed by immediate system restart at windows loading screen: high
BSOD inside windows: inevitable
Looking at the evidence, two memory tests say the ram is fine, and ASRock says the memory is compatible... I'm totally confused. Ideas? Thanks.
i5-2500k
F3-12800CL9Q-16GBXL
Windows 7 64bit
