Motherboard: MSI 790FX-GD70
CPU: AMD Phenom II X4 965 Black Edition
New Memory: 2x4GB F3-12800CL9D-8GBSR (Sniper)
Old Memory: 2x2GB F3-12800CL9D-4GBNQ
I have had no problems running the above system (Mobo and CPU) with the old memory. However, I purchased the new memory and have had many issues. I put in 1 stick and tried to boot but there was a "CMOS Checksum Bad" error. I cleared the CMOS and then booted again. This time there was a "CMOS Settings Wrong" & "CMOS Time/Date Wrong" error. I went into the CMOS settings and set all of the settings that are mentioned in the sticky about AMD cpus and memory. When I save the settings and continue it reboots and says "CMOS Checksum Bad" again. If I put my old memory in and load the default settings for the CMOS then it works fine and will boot fine so I know it is not a problem with the battery.
I bought more G.Skill RAM because I have always had good experiences with it. Also, this RAM was listed as compatible with my Mobo. Hopefully someone can figure it out
Any help is greatly appreciated!
Thanks!
Thanks!
