I have a the same problems too ..
i just bought new G.Skill Ripsaw F3-17000CL-8GBXL DDR3-2133 Memory.i have 4 of these .
I have a Asus M5A97 Pro AM3+ and i got a AMD 6 Core FX 6100 3.3Ghz .
Anyways befor i bought the Asus motherboard it said it would support DDR3 2133 .
I installed my G.skill Ripsaw DDR3 2133 to the Asus motherboard & updated the Asus motherboard to the last bios .
Basically the Asus motherboard keeps crashing and rebooting & even blue sccreening when set at DDR3 2133 so i have to reset it back to default at DDR3 1600 .
As far as im aware the Bios has the correct voltage settings for my memory at 1.5 v so i do not not why this is happening .
I contacted Asus and they blamed it on my G.Skill Ripsaw memory ,saying the voltages for it can not be set right in my bios and i would have to contact the vendor or manufactor ??
I tested all 4 memory modules singley so no problems there .
Can anyone help ?
Can anyone help ?
