I am having problems using the G.Skill DIMM 16 GB DDR3-2133 Quad-Kit (F3-17000CL9Q-16GBZH) on my Asus P9X79 Pro Motherboard while using XMP. If I use the default settings in the BIOS (newest Version 0906) everything works fine but if I use the XMP Profile 2133 MHz I get errors when using MemTest (Version 4.0 from HCI) and the same when using Prime95 (Version 27.3). I also already tried XMP Profile1 and Profile2 but nothing changes.
My retailer already replaced me the first kit but the problems are still the same!!! So therefore I believe that the modules are fine.
Does anybody has a clue to solve my problem?
Regards
My exact Hardware is:
CPU: Intel Core i7-3930K (C2 Stepping)
Motherboard: ASUS P9X79 Pro (Bios Version 0906)
RAM: G.Skill DIMM 16 GB DDR3-2133 Quad-Kit (F3-17000CL9Q-16GBZH)
Harddisk: OS is on a Crucial RealSSD C300 with 128GB
OS: Windows 7 Prof. (64bit)
CPU Cooler: Noctua NH-D14 SE2011
GFX: GeForce GTS 450 passiv
Power: Enermax Modu87+ with 500W
Tower: Lian Li PC-6B Midi-Tower
Additional Coolers: front: be quit Silentwings USC 120mm; backwards: be quit Silentwings USC 140mm
Regards
