Hello everyone!
I am planning on moving to Ivy Bridge 3770K+ a Z77 mobo soon,and for that i would need a good DDR3 memory,i was thinking at least 2133 branded(17000)
The mobo will be either ASRock Fatal1ty Z77 Professional,or Asus Asus Maximus V Formula-my local reseller said they will arrive shorty,maybe 10-15 days max ,from now
So,i put an eye on G.Skill RipJawsZ F3-17000CL9Q-16GBZH 2133,CL9,but i am a bit conserned about the fact its designed for x79 systems
Should i be worry?
Should i look for something else?Like RIpjaws X or those low profile Ares modules?
Should i wait for a Z77 marked memory from G SKill?-the problem is i already have the CPU,and the mobo will arrive soon,but i dont have any suitable memory,only a 6x2gb G-Skill 1600 CL,which i currently use on my X58 build,but i am afraid it will be incompatible for the new one
Currently,i am a I950 x58 user,and i dont have a suitable ram for my next setup,so i need rapid help,if possible pls
Should i be worry?
