Ram issues
  • Ram issues
    Hey I been dealing with blue screen since I built my computer it comes down to Faulty Ram. I went into my bios in set the FSB/DRAM to 1:2.66 which is 1066 is this how I should under clock it if its to much for my mother board? I have this ram at the moment with MSI 760GM p-23 mother board if so Should i look into another mobo or Ram?
    http://www.newegg.com/Product/Produc...618caafaa34172
    Code:
    Loading Dump File [C:\Users\Owner\_jcgriff2_\dbug\__Kernel__\__proces sed_BSOD_dumps__\__2012-03-16__05.16____\031612-18283-01.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    Symbol search path is: SRV*c:\mss*http://msdl.microsoft.com/download/s...wnload/symbols
    Executable search path is:
    Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Built by: 7601.17727.amd64fre.win7sp1_gdr.111118-2330
    Machine Name:
    Kernel base = 0xfffff800`02c54000 PsLoadedModuleList = 0xfffff800`02e98650
    Debug session time: Fri Mar 16 15:48:13.497 2012 (UTC - 4:00)
    System Uptime: 0 days 1:52:49.105
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    Use !analyze -v to get detailed debugging information.
    BugCheck 7F, {8, 80050031, 406f8, fffff9600013718f}
    Probably caused by : memory_corruption
    its the RAM time for a RMA but i think i rather buy some Crosair ram any ways FFS
      What are you working with CPU/mobo? to run those sticks at 1066 you'd be looking at 8-8-8-24 normally, but CPU can play in as can mobo i.e. Intel socket 1155 or socket 775 big difference on setups, AMD? bigger differences. With most any can run Memtest on each stick individually to test if sticks are bad, but without more to work with here not a lot I can do till have more info
        Msi 760GM p23 FX I just ran memtest for 4 hours 3 Runs found 24 Errors. in this is at Stock speeds 9.9.9.24 1.5v. Should I RMA in how long would it take because I Can't miss out on school work.
        Could it be my mother board that cant handle it why im getting Errors? or just the ram it self it holds up too 16g ddr3 1333 mhz
        AMF fx 4100 is my CPU with Radeon 6570 iceQ HD card crosair cx430 psu
          I'd check for the latest BIOS and try w/ that, otherwise I posted RMA info on your General Discussions post
            not sure how to flash it and if i do it wrong I void Warranty :{
              They have easy instructions on their web site, might also see if any of your friends/co-workers have messed with PCs and have done it to help, with most all mobos it's a snap these days, nothing like even a couple years ago.
                I'm thinking of getting new ram any ways going go with the AMD performance the one that was tested with this board in if it still fails I'll be buying a gaming mother board along with it
