Hello!
I'm having a very strange issue, and I'm not sure what it could be, I recently upgraded my system, installed 16GB of RAM, and I've noticed something strange, I rebooted went into Windows, seen that only 12GB of RAM were usable out of 16GB, rebooted, 16GB of RAM is available, rebooted again, works no problem, rebooted again later on, 8GB of RAM is only usable.. I did memtest and it passed, no problems..made a RAM disk (when it was allowing me to use 16GB of RAM) and it worked under high load no issues, I've reset my BIOS, updated it to the latest 2.22 version on the MSI website, I haven't reseat the RAM yet, well because I'm using a very large cpu cooler which is right on top of the RAM, in order for me to reseat the RAM, I'd need to remove it, and it would be a pain in my ***..however I checked and all the DIMMS are securely in place (from what I can see)
I have no memory remapping option in my bios, I've been googling for days now, and I can't find a solution, so hopefully someone can point me in the right way
RAM: http://www.newegg.com/Product/Produc...82E16820231460
EDIT: The RAM seems to be going into "Hardware reserved"
EDIT 2: I checked msconfig advanced option, max memory is unchecked.
PSU: 700w cooler master
Could someone help me out here?
Summary
Operating System
MS Windows 7 Ultimate 64-bit SP1
RAM
16.0 GB Dual-Channel DDR3 (11-11-11-28)
Motherboard
MSI 990XA-GD55 (MS-7640) (CPU 1) 39 ?C
Graphics
Philips (1920x1080@60Hz)
AMD Radeon HD 7900 Series
Hard Drives
59GB OCZ OCZ-VERTEX3 ATA Device (SATA) 30 ?C
488GB Hitachi Hitachi HDS721050CLA362 ATA Device (SATA) 34 ?C
Operating System
CPU AMD FX(tm)-8120 Eight-Core Processor
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR3
Size 16384 MBytes
Channels # Dual
CAS# Latency (CL) 11 clocks
RAS# to CAS# Delay (tRCD) 11 clocks
RAS# Precharge (tRP) 11 clocks
Cycle Time (tRAS) 28 clocks
Bank Cycle Time (tRC) 39 clocks
Physical Memory
Memory Usage 10 %
Total Physical 16 GB
Available Physical 14 GB
Total Virtual 16 GB
Available Virtual 14 GB
Motherboard
Manufacturer MSI
Model 990XA-GD55 (MS-7640) (CPU 1)
System Temperature 39 ?C
BIOS
Brand American Megatrends Inc.
Version V22.2
Date 12/19/2011
Voltage
+3.3V 3.280 V
CPU CORE 1.296 V
VIN2 2.960 V
VIN3 1.376 V
+5V 5.886 V
+12V 11.968 V
VIN6 2.480 V
VSB3V 3.200 V
CMOS BATTERY 3.216 V
Graphics
Monitor
Name Philips on AMD Radeon HD 7900 Series
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State enabled, primary
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Memory 4294966272 MB
Memory type 2
Driver version 8.950.0.0
MOBO: MSI 990XA-GD55 AM3+ AMD 990X SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Summary
Operating System
RAM
Motherboard
Graphics
Hard Drives
Operating System
RAM
Memory slots
Used memory slots 4
Free memory slots 0
Memory
Type DDR3
Size 16384 MBytes
Channels # Dual
Physical Memory
Memory Usage 10 %
Total Virtual 16 GB
Motherboard
Manufacturer MSI
BIOS
Version V22.2
Date 12/19/2011
Voltage
+3.3V 3.280 V
CPU CORE 1.296 V
VIN2 2.960 V
VIN3 1.376 V
+5V 5.886 V
+12V 11.968 V
VIN6 2.480 V
VSB3V 3.200 V
Graphics
Monitor
Monitor Width 1920
Monitor Height 1080
Memory type 2
