System componants
Amd athlon 2x2 250 regor "older hardware"
Ga-990fxa-ud3 rev 1.1
G.SKILL Sniper Gaming Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9Q-16GBSR
Kingwin 850 power supply
1. Installed all memory an it worked, till i started to install drivers it then crashed.
2. Went to post 3 beeps no post.
3. Cleared the cmos by taking battery out an unplugging unit.
4. Put battery an cord in an went to post an 3 beeps.
5. Tried all memory in slots 3 and 4, 2 at a time it worked an posted so memory is good.
6. Tried them in slots 1 and 2, 2 at a time an idividually, 3 beeps.
7. Tried in slots 1 and 3 for dual channel 2 sticks at a time, same 3 beeps.
8. Tried in slots 3 and 4 for dual channel 2 sticks at a time.same 3 beeps.
9. So now im stuck in single channel mode 2 sticks in slot 3 and 4.
10. I'm thinking cpu or motherboard i need advice please as i need to let te newegg no so i can rma motherboard if its faulty. Thanks if you can help much appreciate it.
