Hi guys,
I need some help. I am at my wits end. I have tried eveything but unable to get this memory over 1666Mhz. Once I past that stage, the settings I tried will either make the system not boot or very unstable. Can anyone give me some ideas?
Here are the Specs:
AMD A8-3870K Unlocked Llano 3.0GHz Socket FM1 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD
ASUS F1A75-V EVO FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard with UEFI BIOS
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7Q-16GBXH
Here is the pictures of what I have now that is stable:
APU 125, Apu Multiplier 29, Memory frequency 1666MHZ, CPU voltage: 1.55V
VDDNB: 1.075V, DRAM: 1.5V, SB 1.1v Voltage: 1.14v, 1.1Vsb Voltage:1.1v,
APU1.2V Voltage:1.2v, VDDA Voltage: 2.5v
Primary Timings: 9-9-9-24 DRAM COMMAND MODE: 2
Here are the Specs:
