I am just reading a while, but just have some additional questions.
I have:
AMD 1100T Cpu
Asus M489GTD Mainboard
Mem: 8gb-kit: F3-12800CL9D-8GBXL and new: F3-12800CL9D-8GBRL (kits have same specs)
no OC!
I run the computer with the F3-12800CL9D-4GBXL (RipJawsX) for some time stable with Bios configs to auto.
Now I got a second 8GB-Kit F3-12800CL9D-4GBRL (RipJaws). Put the new kit to board an left all settings to Auto.
I just started to boot memtest86+
There are thousands of errors. So I thought there is a problem with the new kit.
I tested the new kit only as ok, after that I tested the old kit as ok.
But both kits together bring me lots of errors in memtest.
Now the question: Does it make sense to mix these two kits? Are there differences, even with the same specs?
Is there any known bug/strange behavior in using this cpu or mainboard?
Or would you suggest to go on with manual Bios settings?
Thanks a lot and best regards,
killah78
I have:
AMD 1100T Cpu
no OC!
killah78
