Hi there guys,as title said i need some advice regarding that memory module kit (F3-12800CL9D-8GBSR (1.5 V), DDR3 1600MHz, kit 2x4GB ) i just bought together with new motherboard (GIGABYTE GA-990XA-UD3 ).Here are screenshots of specs :
Noticed in BIOS that memory runs at 1333 Mhz,is it possibly to make it run steadily on default 1600 Mhz without taking chances to burn my motherboard or cpu down?
Could i simply apply those settings from this thread :
Or my choice of memory modules for that motherboard wasn't best choice? Any opinion is appreciated.
Regards
Edit: cooling cpu isn't problem,i have watercooler from Corsair H80 mounted.
Regards
