I decided to build a new PC devoted to Image Analyzes.
Lian-Li PC V2120
Corsair AX 1200 Watts
ASUS P9X79 Deluxe
Intel Core i7-3960X
Noctua NH-D14 SE2011
G.Skill F3 - 17000CL11Q2 - 32GBZL
NVIDIA Quadro FX5800
OCZ RevoDrive3 x2 SSD
Windows 7 Pro 64bit SP1
EIZO ColorEdge CG275W
When started, Windows7 recognized the FX5800 and installed the driver version 185,93 (!)
Definition 2560x1600px :: OK
Connected two (2) WD 1TB > Restarted
Trying right clic to open "Driver Management" :: First error:
[ Microsoft Management Console stopped to function ] = translated from french version
Disconnect the two WD 1TB > Restarted.
New errors all the time: (I have to translate from franch Windows7)
[ Display Pilot is not responding anymore but has recovered ]
Or
[ Display Drive NVIDIA Windows Kernel Mode Drive version 185,93 is not responding ]
System stopped and must be restarted !
Tried several NVIDIA pilote versions until the latest version 276,52 (no way !)
Tried by replacing the FX5800 by a FX4800 (no way !)
Updates ASUS BIOS from 0802 to 0906 (no way)
Updated ALL ASUS files (no way)
Removed the RevoDrive > installed VelociRaptor 300GB HDD
Installed Windows 7 Pro 64bit without the SP1 (older version) = (no way !)
And so on...
I wonder if some G.Skill members can help me ?
I left the automatic configuration for the processor (3.3GHz) as wel as for the DDR3's
I also would like to know if there is a specific advised configuration for the G.Skill's ?
I will realy appreciate any positif (!) advice and thaks in advance,
Regards,
Jean
Lian-Li PC V2120
ASUS P9X79 Deluxe
Intel Core i7-3960X
Or
And so on...
Regards,
Jean
