Counterfeit G.SKILL memory kit ??
Will have GSkill take a look, but know on occasion they have tried some of the sets with black PCBs, not sure if it's for appearance/marketing or shortage of available components, i.e. manufacturer short of green PCB so the substitute the same in black, know that's happened to other manufacturers as well
Originally posted by GSKILL TECH View PostBoth should be G.Skill, but looks like the "newer" one is actually older.
Did you purchase from same place?
Are you attempting to use both kits in the same system?
Are you attempting to use both kits in the same system? : Yes, is why I've bought this 2nd kit, this kit is awesome running 9.9.9.24 1T @ 1764MhzLast edited by plopingo; 02-21-2012, 04:56 PM.
With two sets, will need to turn off XMP if using it, and make sure base timings and CR set manually. May want to start with base DRAM voltage and MC (Memory Controller) voltage but may have to raise one or both with two sets
