Hi !
Just building me a new PC :
-Intel i5 2500K 3,3 ghz
-Asus Sabertooth P67 (Rev B3)
I have to make a choice between :
-Ripjaws X Series - 8Go (2x 4 Go) PC12800 1600 Mhz - CL9 - F3-12800CL9D-8GBXL
-Sniper Series - 8Go (2x4 Go) - PC12800 1600 Mhz- CL9 - F3-12800CL9D-8GBSR
I am a gamer so I was interested by the Snipers until I saw the ?Sandy Bridge compatibility? on the Ripjaws.
This is not mentioned on the Snipers so I am a bit confused because I don?t know if it is really important ?
I checked, both are visibly compatible with my MOBO !
So, what is really the differences between those two ?
Do you think the Snipers are really the good choice for me ?
Does my MOBO support the XMP profile of the Snipers ?
Thank you very much !
