Hello all,
Here is my config:
Model of the motherboard: Asus P8Z68 Deluxe/Gen 3
Model of the memory: F3-14900CL9Q-16GBXL (4x4GB)
Model of the CPU: Core i7 -2700K
Here is the issue:
To begin, I think I possibly have two bad chips out of the 4. The chips have sequential serial numbers:
12060240052201 through 204
This machine is a brand new build, all of the components are new. I got the new machine put together, and on the first boot, I never got to BIOS, and the Q-Code on the MB showed 2E. So I started to isolate the memory. I plugged the chips in one at a time into the A1 slot on the MB. With either 201 or 202, the system would post and enter the BIOS config. With 203 and 204, the system would not post when either was installed, and continued to show 2E on the Q-Code display, even after trying the MemOK button.
So I went back to chips 201 and 202, and tried to have them both in the machine. It didn't matter if I had them in A1/B1 or A2/B2, the system would post, and I could either go the MemOK! route or manually set the timings to 9/10/9/28, but I couldn't get a MemTest86 to get past 5% before locking up. With either 201 or 202 installed in A1 by themselves, I could successfully complete a round of MemTest86.
What other tips or advice do folks have on how I can continue troubleshooting to help resolve the issue? Any help or info in appreciated. Thanks!
Here is my config:
Here is the issue:
