Motherboard: Gigabyte H67MA-UD2H-B3
CPU: Core i5 2500K
RAM: G.Skill Ripjaws F3-12800CL9D-8GBRL
OS: Win 7 Pro 64bit
I have been running this machine without problems since May last year with 8GB of RAM.
We are now using more virtual machines at work and seeing as how cheap RAM is we decided to double the RAM to 16GB.
When we added the second (identical to first) kit of RAM the system slows down to the point of not being usable (3 minutes to load Windows compared to the normal 20 seconds).
To clarify there are two kits of identical RAM. Each kit is two 4GB sticks. Two kits totals 16GB (i.e. 4 x 4GB identical sticks).
The system is fine with 1 X 4GB, 2 x 4GB and 3 x 4GB but as soon at the four stick is added it runs amazingly slow.
Tried swapping the sticks around to see if one (or more) of them is faulty with no luck. The behaviour is the same regardless of which sticks are used so therefore the RAM is not faulty.
Am currently running the system with 3 X 4GB sticks and it is fine but would like to get to the bottom of the problem.
Anyone seen a system slow to a crawl with 16GB RAM (i.e. all four slots used)???
Any suggestions would be appreciated....
CPU: Core i5 2500K
OS: Win 7 Pro 64bit
