Hi to all! You are great!
Around 6 mounth ago I bought 4 modules 2GB each of F3-17000CL9-2GBXL to place in my ASUS P8Z68-Deluxe Motherboard.
Since now I've tried to find a stable operativity at 2133Mhz but the SPD were totally wrong.
As you can see in the image below CPU-Z is telling that with XPM profile I should set 9-12-9-29 at 1.6V. I've tried but this timings works only with 2 modules at time not with all 4 togheter.
However after 6 month of reserch I've found that with 11-11-11-30, 1.65V of DDR Voltage and a little push of VCCIO at 1.10V all works fine, as you can see below.
But my question is, do you have some specs to reduce the 1.65V or the VCCIO? Or more, do you have better timings you know to work for 2133Mgh XPM-2134 profile with 8GB in 4 sticks?
Thanks guys! You are great memory producers!
Finally these are my others specs:
