Ok first off computer specs:
Model of the motherboard: Biostar A770e3
Model of the memory: 8 Gb (4 x 2gb) F3-12800CL9D-4GBNQ
Model of the CPU: Amd Phenom II x2 555 unlocked to Amd Phenom x4 B55 (955) 3.2ghz (stock)
provide the RAM in question: above
the amount of RAM: above (issue with 2nd set)
mobo: above
BIOS version: default: 080014 (don't want to update cause that has been reported to interfere with the unlock ability).
CPU: above
whether you are OCing: I am on the CPU (modifier set to 18.5 for a 3.7ghz), And yes I tried setting DDR3-1333 and fsb to 240 but my fourth unlocked core can't handle 240 fsb even at default modifier. Also Overclocking the GPU.
GPU (and driver): EVGA Geforce 560 ti Classified, driver is the only one out for it...285.96 i think.
OS version Win 7 64bit Professional Addition
ok to the issue:
So i set the ram manually to DDR3-1600 in the bios manually and changed the settings to 9-9-9-24 which are the timings the ram is rated for. (used method 2 from this forum)
The first set (in slots 1 and 2) (the set I have had for 6-7+ months) are reporting and running at DDR1600 (800 mhz each) (PC3-12800H) very well.
The 2nd set (in slots 3 and 4) (newly installed 3/4 days ago) is only reporting a max bandwidth (CPU-Z) of 667mhz each (PC3-10700) (or DDR-1333) and running at this speed.
I am wondering if there is a way to make the 2nd set to run at the same speed as the first set, or if its an issue with the ram, or just something I'll have to live with. And if it is something I have to live with should i set the first set back to 1333?
I am not having any issues with the ram running anything and I passed 2 rounds of memtest 86+, tho I haven't run it longer yet. First spotted the problem in 3dmark11 while OCing the GPU.
Thanks for any help/suggestions you may have.
mobo: above
CPU: above
ok to the issue:
