Built new system with Asus P8Z68-V LE SandyBridge motherboard, Core i5-2500, and F3-12800CL8D-8GBXM memory. Machine won't POST with both DIMMs installed, but will boot up with only one installed. I've updated to latest BIOS, and tried default and XMP settings in the BIOS. It will work with either DIMM installed singly, and I tried different slots so it doesn't seem to be a bad DIMM slot. Suggestions?
F3-12800CL8D-8GBXM + Asus P8Z68-V LE = no POST
If some of your DIMM slots don't seem to work, your heatsink backplate might be touching the back of the motherboard causing a short. I have a P8Z68-V LE and I had a similar problem. The solution was to use the heatsink's included electrically-neutral plastic spacers between the motherboard and the backplate. That solved it for me.
