F3-14900CL9D-8GBXL help
  • F3-14900CL9D-8GBXL help
    I just recently bought 16 gigs of this ram (F3-14900CL9D-8GBXL)
    and im wonderind if it is going to be compatable with my new set up
    cpu ( AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core FD6100WMGUSBX )
    mobo ( GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD )
    this is only my 3rd build and im still new to it... i never used gskill and i didnt do my research on this model or ram.. if you can please give me your best input!
    I'd start with 1 set and get it stabilized, then add the second, may well have to make adjustments to DRAM and/or CPU/NB voltages...problem here may be any time you mix two sets (even of the same model) it can be problematic, especially with AMD CPUs. Have seen where the Zambezi's at times have trouble with more than 1 stick per channel at 1866, if that comes up may try dropping to 1600 CL8
      Input the basic memory settings, frequency, timings, and voltage, then you may need to raise the CPU-NB Voltage to stabilize full slots.
