Asus M4A88TD-V Evo usb3 - F3-10666CL9D-8GBRL
  • Asus M4A88TD-V Evo usb3 - F3-10666CL9D-8GBRL
    I have purchased these G.SKILL Ripjaws Series 8GB (2 x 4GB) " F3-10666CL9D-8GBRL" ram sticks.
    In the near future I will be purchasing the Asus M4A88TD-V EVO USB3 motherboard specifically because of its features and the capatibility it has with my AMD Phenom II X6 1090T Black Edition.
    I have ran into an issue though. On the motherboards manufacturers website unfortunately didn't have a updated compatibility list that had this ram stick type on it. I have done alittle bit of research and have found different outcomes upon people using these item together, but they did not have the same CPU that I will be using.
    So this is when I decided to come here and ask about it based on other peoples experiences using common hardware as I to see if it really is compatible and will work.
    Or, hopefully I get lucky and get a adminstrators response who knows specifically if they will work or not.
    CPU: http://www.newegg.com/Product/Produc...82E16819103849
    MOTHERBOARD: http://www.newegg.com/Product/Produc...82E16813131646
    RAM STICKS: http://www.newegg.com/Product/Produc...82E16820231311
    Yes, should work with no real problem, will want to ensure you have the latest BIOS installed, then install the sticks and ensure the timings are read correctly and should be good to go...might anticipate the need for a slight CPU/NB voltage increase for 8GB, but chances are good it won't be needed
      Awsome, thank you. After I receive my board in the mail, I will reply back here and let you know how everything turned out.
        We'll be looking for it, have a gud 1 !
          Got my. Motherboard yesterday in the mail finally. Hooked everything up. Started it up, the post Went completly fine. Entered bios at ease.
          My timings for my ram were already set correctly. Put Windows in and it installed within 20 mins.
          Haven't had a single problem.
          I greatly appreciate your support.
            Having an early Xmas then, Enjoy!
