Hi there. So I have been battling with ram for a while now.
My setup is:
M5A97 Asus
AMD 970 X4
I have been having BSOD problems since booting windows because originally I had 8gb kingston which I then traded a friend for some 8gb of Corsair. Which was a bit more stable on auto settings but was still BSOD every 4 or so days. And when I changed the settings (adjusted to correct timing, upped the CPU-NB volt by .1v upped the ddr3-1600mhz basically followed all the steps outlined in your guide to memory tuning method 2 even though I didn't have g skill) and that made my system blue screen in like 2-4 minutes every time. And since it bluescreened so fast i didnt even try method 1.
Now I am thinking about buying the G skill 1333mhz 8GBXL because its on my QVL (the Corsair was also on QVL but apparently that didnt change anything) but Im just wondering if I run into problems with comp BSOD on auto settings what ram settings should I change to make it stable?
Also Im posting before hand because so far every stick of ram has BSOD on me so might as well get answers now instead of waiting for it to happen. Also is there any other advice or different course of action you might take if you were in my position?
THANKS!
My setup is:
M5A97 Asus
AMD 970 X4
THANKS!
