Hi to all,
i've a doubt, i've a SNIPER F3-12800CL7T-12GBSR kit, and an asus p8z68 deluxe, the voltage ram is 1.6v, but intel says that on 1155 cpu the maximum limit on the dram voltage is 1.5v +5%, then 1.575v, they says that using a higher voltage, invalidates warranty and could break the cpu itself, now can i set dram voltage to 1.6v and use my g.skill kit or i must change ram? It is strange that on g.skill website my memory kit is compatible with my motherboard.
Thanks in advance
Thanks in advance
