RMA'd 2 sticks awhile back and noticed this on my gigabyte board. Was advised that it was probably an error with the GB board. Just upgraded to an ASUS CHVF 990FX and getting the same reading. Can someone please explain? Why are PT numbers the same but max bandwidth different? Sorry for the large image did not know that it would not be resized.
Strange CPUZ SPD Reading
AMD Phenom II 965 BE 3.8GHZ
ASUS Crosshair V Formula 990FX
4Gx4 GSKILL F3-12800CL9D 8GBRL 16GB
Cool Noctua|NH-D14
NZXT Sentry 2 Touch Screen Fan Controller
HIS Radeon HD6950 2GB 840/1325
HIS Radeon HD6950 IceQ X Turbo 2GB 900/1325
2 Crucial RealSSD C300 CTFDDAC128MAG-1G1 Raid0
WDC WD 1002FAEX 00Z3AO 1TB SATA3
Cooler Master HAF 922
Enermax Revolution 85+ 1020W
Win 7 Home Premium 64 bitTags: None
Does your mobo have the latest BIOS? The one stick showing a 2 in the tRAS may be being misread, the differences in the maxbandwidth may come from sets of sticks from diffferent production lots with the hiogher being the newer default boot settings...
Thanks for your reply. I am running the latest beta Bios however these results were the same on my previous official Bios and on my previous board. Will this affect performance and how do I fix it?AMD Phenom II 965 BE 3.8GHZ
Cool Noctua|NH-D14
It will not affect performance, there is no need to fix it. The max bandwidth just shows the max the motherboard can default the memory. You should not use default settings anyway, you should use XMP. Look at the XMP Profile of each module, they are the same, that's all that matters.
Input the proper settings, and you should be ready to go.
So, just to make sure I am clear, at the moment all 4 sticks are running at 800, 2 of the sticks just are not capable of reporting the correct speed. This makes me feel much better about my ram.
Thanks alotAMD Phenom II 965 BE 3.8GHZ
Cool Noctua|NH-D14
Well, I don't know whether they are operating at 800, you need to show me or look in the memory tab. The memory tab shows current operating values. The SPD tab just shows suggested values and standard values. The two sticks are reporting correctly, they are just reporting lower because they were produced at an earlier date. Before, the standard was DDR3-1333, now it is DDR3-1600, so that's why the kits are displaying different values. It does not affect performance or anything, so it should still work the same.
