Help
  • Help
    Will the ASUS crosshair IV formula support the G-Skill 8GBXL Ripjaws X RAM cards
    any help is much obliged.
    Simple answer is Yes, going further, they will support Ripjaws X up through 2000 sticks (i.e. 1333, 1600, 1866, 2000 sets) although that's the mobo itself....you also need to figure in that you need a CPU that handle what you want to install. AMD CPUs have limitations, i.e. a 965 rev C3 would prob be the min you'd want for 1600 sticks, faster than that you'll want to go to a better CPU......also depends on your OCing experience the faster the sticks the more involved in setting them up with timings/DRAM voltage/BUS freq/CPU/NB voltage/etc
      thanks for that, the CPU I'm getting is a AMD quad core 970 black will that support the RAM?
        sorry to be more specific the CPU is an "AMD Phenom II X4 Quad Core 970 Black Edition "125W Edition" 3.50GHz" will this support the RAM?
          Can prob do 1866, if not native can drop to 1600 and tighten down timings and prob get better than 1866 native performance
            With the 970 CPU, it will be no problem at all.
