Hi Guys,
I'm having a VERY similar issue to "w0lf" in this thread.
I'm running;
Motherboard: ASRock Extreme7 Gen3 (UEFI v1.30)
Memory: GSkill RipJaws GS-F3-17000CL9D-8GBXLD
CPU: Intel Core i7 2600k
GPU: eVGA Geforce GTX580 1.5Gb 015-P3-1582-KR
OS: Win7 Ultimate x64
The memory is rated at 2133Mhz, 9-11-9-28 and as you can see is correctly detected in the XMP 1.2 Profile section, however in the actual 'BIOS' the DRAM frequency is only 1600, and the CAS timings are 11-11-11-28.
I've tried manually updating this to those rated above, but i get a code of "45" on the Dr. Debug LED on the motherboard, and a non-boot hang. I have to reset the CMOS to boot normally.
As per "w0lf" I can boot and everything runs relatively normally, except some steam games, same as him, Deus Ex crashes me out.
I have raised the issue with ASRock and am waiting for a reply.
Just wondering if anyone else has had a similar issue, and has had some success in getting the RAM frequencies sorted out?
Thanks!
Draxxx
I'm running;
Thanks!
Draxxx
