Hello, I am new to the computer building and overclocking scene. I have recently upgraded my computer by purchasing a new motherboard, processor, and RAM. The rest of my hardware are from my old computer. My Computer:
Asus p8z68 v-pro Motherboard
Intel core i5-2500k Processor
G.skill Sniper Low Voltage Series DDR3-1600 9-9-9-24 1.25v RAM
Nvidia geforce 8800 GT GPU
Western digital caviar black 640gb HDD
A 750w Power Supply (not sure of the brand, need to take it out of my case to find out)
The RAM I have purchased was the G.skill Sniper Low Voltage Series ram sticks (F3-12800CL9D-8GBSR2) DDR3-1600 9-9-9-24 @ 1.25v stock settings. However, upon receiving my RAM sticks I came across another pair of ram sticks from G.skill (F3-12800CL8D-8GBXM ) DDR3-1600 8-8-8-24 @ 1.5v stock settings.
I am wondering which set of RAM sticks are better for overclocking? I will be overclocking once I get sufficient cooling for my components. I see on the G.skill website that the 1.5v ram sticks were made specifically for the Sandy Bridge processors, is this the case as well for the low voltage series ram sticks? Is 1.5v the optimal voltage to overclock with my i5-2500k processor? I do know that you should not exceed 1.65v on the ram voltage or you may damage the processor, but are the Low Voltage ram sticks capable of going from 1.25v to 1.65v and will there be any difference in on-paper performance? I also hear that with the Sandy Bridge processors, you can't really overclock ram is this true? I just want to know which ram sticks around this price range is optimal to overclock with my processor and motherboard, so if there are other ram sticks I should consider besides these two please let me know. I am curious, will there be a decrease in performance if I have 4x 4gb of these rams in my motherboard over the dual channel 2x 4gb? I am still debating if I should have 8gb or 16gb of ram for my computer, but for my questions above let's assume I stick with 8gb total. Thank you.
One final question, I'm not sure if this is correct but when I go into my BIOS I noticed that my low voltage series ram sticks were running at 1.35v. I lowered it to 1.25v and restarted my computer but it was processing everything very slowly so I changed it back to the AUTO setting (which automatically sets it to 1.35v) and the speed returned to my system. Is there a reason for this?
