I'm building a pc with the Asus P8Z68-V PRO/GEN3 and Core i7 2600k. I'm trying to decide which ram to buy. I'm looking at 16gb because when I'm not playing games, I have several Virtual Machines running. Currently, I'm looking at the following 2 kits. Specwise they look almost the same. Other than the heatsink, the only difference I can see is that the Ripjaws is a Quad Channel Kit and the Snipers is a Dual Channel Kit. My motherboard is only dual channel if that helps. Is there any benefit of one over the other?
F3-12800CL9Q-16GBXM
http://www.newegg.com/Product/Produc...82E16820231478
or
F3-12800CL9Q-16GBSR1
http://www.newegg.com/Product/Produc...82E16820231480
F3-12800CL9Q-16GBXM
or
