I've been running 8GB GSkill Ripjaws F3-12800CL9D-8GBRL on a ASUS P5N64 WS Pro and recently decided to move up to 16GB and I got 8GB GSkill RipjawX F312800CL9D-8GBXL. When I installed the new sticks the computer wouldn't boot. I got a second kit thinking that was the problem and that didn't help. I got it to boot by upping the NB voltage and the memory voltage to 1.66V. However if I populate all 4 slots with the 'X' version the computer won't pass memtest 4.20 consistently failing on test #5. If I put a stick of the Ripjaws (not 'X') into slot 1 (closest to the cpu) then all the computer passes memtest. Any idea what is the difference between the Ripjaws and RipjawsX that would account for this? Can I mix Ripjaws (slot 1 and 3) and RipjawsX (slot 2 and 4)?
Thanks,
Thanks,
