i currenly and running 8 gigs
G.SKILL
SeriesRipjaws Series
ModelF3-12800CL9D-8GBRL
Type240-Pin DDR3 SDRAM
Capacity8GB (2 x 4GB)
SpeedDDR3 1600 (PC3 12800)
Cas Latency9
Timing9-9-9-24-2N
Voltage1.5V
and new egg has the ripjaws x on sale, and thinking about upgrading to it.
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
BrandG.SKILL
SeriesRipjaws X Series
ModelF3-12800CL9D-8GBXL
Type240-Pin DDR3 SDRAMTech Spec
Cas Latency9
Timing9-9-9-24
Voltage1.5V
My board is a asus, (am work and forget the exact model), but running a x6 3.0.
and have the extra extra 2 slots of ram. Only difference is the timing with the current set is 9-9-9-24 2n... would the x set work ok as dual channel 16 gigs?
G.SKILL
Cas Latency9
Timing9-9-9-24-2N
Voltage1.5V
BrandG.SKILL
Cas Latency9
Timing9-9-9-24
Voltage1.5V
