Hi
I will be buying G Skill memory next week, but prior to that I want to ask you for an advice on two things.
My comp spec is as follows:
Motherboard - ASUS M4A89GTD PRO/USB3
CPU: AMD Phenom II X6 1100T Black Edition
Graphics card: Zotac Geforce GTX 570 AMP! Edition
Cooler: Scythe Ninja 3
System hard drive: OCZ Vertex 3 SATA III 2.5" SSD - 120 GB
1. What is the difference between these models with the same speed and latencies?
[ SNIPER ] F3-12800CL7D-8GBSR http://www.gskill.com/products.php?index=386]
[ RipjawsX ] F3-12800CL7D-8GBXH http://www.gskill.com/products.php?index=357]
[ Ripjaws ] F3-12800CL7D-8GBRH http://www.gskill.com/products.php?index=317]
or these
[ RipjawsX ] F3-12800CL8D-8GBXM http://www.gskill.com/products.php?index=356]
[ Ripjaws ] F3-12800CL8D-8GBRM http://www.gskill.com/products.php?index=318]
and which ones are recommended for my system build? The thing I need to improve is the gaming quality and overall performance with few applications opened.
2. Will it make a real, noticable difference for my build, if I buy CAS 8 instead of CAS 7 memory from the models above? I will be manually overclocking them to achieve better performance (I guess with that spec I need to do it manually anyway).
Or maybe shall I go for CAS 6 and buy 2x [ RipjawsX ] F3-12800CL6D-4GBXH and use all 4 memory slots?
Or maybe I'm totally wrong and for my build you recommend completely different type? I can already tell that Flare models won't fit under Scythe Ninja 3 cooler and are unfortunately too expensive (at least in my country)
Thanks in advance for any help.
or these
