Help for testing memories to see if they are working on right speed and cas
  • Help for testing memories to see if they are working on right speed and cas
    I am new here i just wanna check if my memories working on correct freq speed and cas latency... Can you tell me how to fix and bios settings If they are not working right speed and latency? and Can you all help me how to check it? thanks
    Here is the info:
    Model of the motherboard: Gigabyte GA-Z68XP-UD3
    Model of the memory: F3-12800CL9Q-16GBRL
    Model of the CPU: i5-2500k
    Easiest way is to download CPU-Z off the net and run it. Check the Memory tab of the program and it will show speed/freq (i.e. should show about 800 as it's Double-Data Rate) and the base timings and CR (i.e. for your sticks, it will be 9-9-9-24 2T (last may show as 2N). If it doesn't show correctly best way is to go into BIOS, enable XMP and select the 1600 profile
      i did download cpu-z and this is what it looks like under the memory tab..
      General:
      type: DDR3
      channels: DUAL
      TIMINGS:
      DRAM Frequency:
      FSB/DRAM: 1/6
      CAS# Latency (CL): 11.0 clocks
      RAS# to CAS# Delay (tRCD): 11 clocks
      RAS# Precharge (tRP): 11 clocks
      Cycle Time (tRAS): 28 clocks
      Command Rate: 2T
      OTHERS ARE EMPTY
      so memories are working on correct speed with wrong latencies? is there a way to fix them?
        ***Forgot to write the speed of memory freq
        ***DRAM Frequency: 802.4 MHz
          Right speed, wrong timings, go into BIOS, enable XMP and select 1600 profile.........or........just manually set timings to 9-9-9-24 2T
            ok.. i will try to see if it works... thank you...
              Ok, let me know what happens, have to check out for the evening, unless I find a wireless spot and take a drive....will check back in the AM otherwise
