Looking to upgrade my ram at the moment, and I've had trouble checking the compatibility anywhere, so I thought I'd ask in here.
(Asus needs to update its compatibility lists)
This should be fine from what I can tell, but any known issues with this?:
Mobo: m4a89td pro/usb3
Ram: Ripjaws x F3-12800CL8D-8GBXM
Cpu(to make sure this will work, as to my knowledge it's fine): AMD x4 965 BE
Cheers in advance guys.
